vidgeek897 Posted June 22, 2017 Share Posted June 22, 2017 Hi guys, I have hdmi modulator with GUI web-based management panel and I need to organize secure and robust access from remote network, I don't want to use straight NAT because you can "brute force" the native auth panel. I need some kind of layer between remote user and NMS via gateway, which will manage logging and auth.I was thinking about 1 channel router(maybe raspberry pi based)... What to choose and from where to start? Thank you! Quote Link to comment Share on other sites More sharing options...
Heath Raftery Posted June 22, 2017 Share Posted June 22, 2017 pfSense running on an old laptop is a popular way of securing NAT networks. If you want to run it on a RPi, don't bother trying to DIY, just use something like this: https://www.netgate.com/products/sg-1000.html Quote Link to comment Share on other sites More sharing options...
David Ingram Posted June 24, 2017 Share Posted June 24, 2017 You could run a VPN server on an embedded PC, such as a Raspberry Pi or Beaglebone Black or a small x86 PC running linux or windows. If you have a firewall/router then a single Ethernet port is all the Rpi/BBB needs. Forward the appropriate port for the VPN you select (e.g. 1194 for OpenVPN) to the Rpi/BBB, and it will then send back local LAN traffic to your modulator. If you don't have a router, you could add a USB Ethernet port or USB 3G dongle, and use the Rpi/BBB as the firewall too. I think this is a bit riskier since there is a single point of failure for a config muckup. I run option 1, where my firewall does the bulk of the internet filtering and only forwards the selected VPN ports to the Rpi/BBB. The only service running on the Rpi/BBB is the VPN server. I use SoftEther, as it is really good and yet free + source code is available: www.softether.org. The config is straightforward once you have the software setup on the server (it has binaries for x86, MIPS, PowerPC and ARM). Management is done with a command line or a nice Windows GUI (which runs fine on Linux with WINE) or MacOS GUI. I connect with the built in VPN clients on Windows 10 and Android, but there is a dedicated client available for Windows, Mac and Linux. The Netgate (thanks Heath) looks like a very nice turnkey product, and might be a better way to go if you don't want to play on the command line. Less chance of a catastrophic config error letting everything in too. If you have a spare Rpi or BBB lying around though, it won't cost you anything to have a go. Quote Link to comment Share on other sites More sharing options...
